TwinTurbo.NET: Nissan 300ZX forum - Re: EGR code issues
Subject Re: EGR code issues
Posted by canyoncarver on April 08, 2010 at 5:09 AM
  This message has been viewed 96 times.
In Reply To EGR code issues/Fuel pressure loss posted by Roundabout136 on April 05, 2010 at 07:25 AM
Message The EGR error code only signifies an issue with the solenoid. Since you checked the solenoid for function, you might also check the ECU pin voltage outputs per the fsm, pin 102. You can also check it at the solenoid connector.
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&slide=176&cycle=off&scale=0&design=default&total=190 ]
If that checks o.k., trying swapping in a aiv or prvr solenoid. They are the same.
